Bouncing Speedometer
JohnGrossi
50
Mar 8, 2010
Lake Zurich, Illinois
My speedometer tends to bounce around more so at low speeds. Going about 10 down the road the speedometer will be bouncing from 0-20. I was thinking the speed sensor, but the problem seems to have a connection with going over bumps too, so I was thinking the gauge itself?
There is only one way to find out.
Take the speedo sensor out and inspect it for damage. mine had the sensor wheel's teeth worn off, you can buy the shaft and wheel from the dealer, instead of the whole sensor.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
