dsm-onster
DSM Wiseman
- 8,592
- 132
- Jul 11, 2004
Bloxom,
Virginia
Speaking about spool speeds from logs on a closed forum doesn't make them any less legitimate. Sorry you don't have the money for link (just messin'
). Let's open that can of worms
. I've confirmed that Sean and Mike are not mistaken about what they've seen on a "closed forum". These turbos generally spool a bit later than what's remarked in this thread. Actual logs from an a accurate logger with a gm map sensor.
I'm sorry but I don't have to own a turbo to know for sure when it typically spools with common boltons. I have access to an incredibly detailed and accurate database. No one tunes their car for later spool (for the most part). Final logs after the tweeking are what I've been looking at.
. I've confirmed that Sean and Mike are not mistaken about what they've seen on a "closed forum". These turbos generally spool a bit later than what's remarked in this thread. Actual logs from an a accurate logger with a gm map sensor.I'm sorry but I don't have to own a turbo to know for sure when it typically spools with common boltons. I have access to an incredibly detailed and accurate database. No one tunes their car for later spool (for the most part). Final logs after the tweeking are what I've been looking at.
