Boost problem
aCer_209
42
Sep 17, 2007
Reno, Nevada
i'm having a problem with boost.
when i hit the gas the turbo spools up fine but it wont stop boosting and its peaking at wot.
my boost gauge only goes up to 20psi and it goes well passed that.
car has no boost leaks.
no bc yet but i have the hks evc, just havnt installed it
whats causing this and what can i do to fix this?
would adjusting the wga fix it?
thanks for taking the time to help.
current setup: K&N Intake, HKS SSQV BOV, 3" Thermal Research cat back exhaust, Megan Racing 3" dp(catless), DNP turbo manifold, Evo 3 Big 16g
Definitely check your wastegate. Doesn't sound like its opening to me. Make sure the arm is still attached to both the actuator and the flapper.
Also check the vacuum line going from the wastegate to the boost solenoid, or the Mnaual Boost Controller, whichever one you have. But it does sound like the wastegate is not opening. Good luck!
Since you dont have a boost controller and if you dont have a stock mbc the only solution you have is to run a vaccuum line from the nipple on the jpipe to the waste gate. That would limit your boost to the wastegate spring pressure (probably ~10psi) but it's safer than an uncontrolled 20+psi.
Sounds like one of your vacuum lines is hooked up wrong, I had this problem when we first put my MBC on, we put a vacuum line on a wrong source and the turbo wouldn't stop boosting.
Nipple on the compressor cover.
For now you can connect the WG directly to that nipple. You will run stock boost ~11-12psi.
Leave the BCS plugged in to the electrical line but no vac lines.
My guess is that you won't have a nipple on the compressor cover since you have an Evo III (although I could be wrong...). So you will have to get a boost source from elsewhere. If you don't have a nipple on the compressor, you might want to think about putting on on the J pipe. Or you can just run a vacuum line from the intake manifold which will work perfectly fine.
X2 on the drill into the j-pipe and jb weld a nipple onto there, that's what I did, works just fine.
Whoops, didn't catch the E3 16G.
Before you tap the J-pipe, look along your intake tract first. Your vac hose might have just fallen off. I doubt anyone who goes through the hassle of installing a turbo would lack the oversight to have a pressure source.
so today i was going to tap into the jpipe, but before i did that i checked the bcs and i noticed that the second hose was pinched. well i got that fixed and now the boost stays between 17 and 19 at wot. when it hits that range in boost it feels like the turbo hesitates to keep spooling. so now if you guys could help me out with that i'd really appreciate it.
(hoses on intake tract are connected)
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
