Boost Leak?
ThUnDaKaT85
82
Feb 5, 2004
Houston, Texas
ok, it just started last night while i was driving. when i press the gas, it still drives pretty hard and once or twice it starts to stutter, and kinda looses a lil power, and if i release and gas it again it doesnt do it. but everytime i go WOT in every gear, it does it. it spudders really bad and just looses a little power. any idea?
Sounds like it could be the infamous phantom knock. I just cured mine. What it would do was i would give it some gas and my boost would go to where it was set but i wasnt going anywhere, actually loosing speed. But if i reved it a lil then it would be perfectly fine. There are many fixes but try a oil change with diff. oil maybe? Also i would suggest some MCC(Mopar Combustion Cleaner). That stuff works great! Hope that helped a little bit.
Good luck
check your spark plugs, also check to see if there is a boost leak...that is what my problem was, my lower ic pipe was leaking at the turbo
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
