jim97gst
- 482
- 3
- Aug 2, 2002
Bethel Park,
Pennsylvania
OK, I made a boost leak tester in preparation for when I install my 16G. I did the test on my fairly stock setup. I am using an air tank. When I get it above 10 psi or so, I can hear a hissing sound. It then goes down to about 5 psi, and then slowly leaks down to 0. The hissing sound seams to be coming from somewhere around the intake manifold. I can't pinpoint it by myself, as I only have about 5-10 seconds after I pressurize it before it hits 5 psi or so and goes away. I tried to have my wife help me out. She confirmed that it was coming from around the intake manifold as well, but couldn't pinpoint it. She simply described it by saying it "sounded deep", like far down into the engine bay.
I've only done a quick inspection of the vacuum lines on the intake manifold, and I know I need to do the soapy water test, and I need to get another car person to help me out, but I've got a question. No matter where the camshaft is rotated, at least one of the intake valves is going to be open, right? Am I possibly just hearing air escape from an open intake valve? Am I doing something wrong with this test?
Thanks
Thanks
