Boost Gauge- Vacuum Route?
always_broken
468
Nov 14, 2006
werx, Utah
Where do you guys route the vacuum hose?
I'm gonna go single a pillar but have't found a way besides through the door> fender> under hood.
Lmk, thanks.
If you take the passanger side fender off there is a gromet that you can go through and it brings it out right under were you need to go to for the a -pillar.
Do you mean the drivers fender? That's a lot of work taking off a fender just to install a boost gauge....
Go with the steering boot... It's easy.. you have to be really stupid to mess it up and the line comes out right where it needs to be for tapping.. good luck :)
Thanks guys, just saw something similar where a guy ran a wire through there to the battery.
So I get the steering column boot hole, but what about hiding the hose on the way down there?
Just snug it between the frame and the dash?
