Boost Gauge Tube Routing
LifIsPeachy02
362
Mar 3, 2003
Middletown, Ohio
Ok, i've had my boost gauge hooked up for awhile now, i wanna re-route it so that its not behind my pedals. Every time i push the clutch i hear the nylon tubing against it. I have it ran down from the a-piller beside the fuse panel, behind the clutch, and through the steering column boot. Is there anywhere else or a better way to run it then thru the sterring column boot? Or atleast so that it doesn't interfere with the pedals??
Thanks guys.
I ran mine through the shift boot by the brake pedal, down under the carpet and routed by that little "foot rest" down there that kinda holds the carpet down. I ran it up from under the door trim, behind the rubber weather stripping, and into my A-pillar. I never feel my clutch pedal hitting it.
