Windshield squirter hose routing [] washer wash tank tube tubing
turbobluestreak
May 28, 2007
Dayton, Ohio
OK little back story, I bought my 95 AWD and the interior was taken apart, covered with dynamat and missing parts. I finally bought the washer tank and hose off ebay for it and I don't know where it goes. I know the back hatch but with mine being covered in dynamat still and wondering if I'm missing a bracket or something that holds it in. Would anyone be willing to take a picture of it installed in the car? I've checked the photos section and came up with nothing helpful.
tbs
One second and I can for you!
:dsm:
Here ya go!
<a href="http://imageshack.us"><img src="http://img228.imageshack.us/img228/2194/1007552ao3.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
<a href="http://imageshack.us"><img src="http://img228.imageshack.us/img228/1429/1007553ay8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/5067/1007555ge0.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
<a href="http://imageshack.us"><img src="http://img228.imageshack.us/img228/7666/1007557mq7.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/9026/1007558ry3.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
:thumb:
:dsm:
I believe it connects to the filler tube near the top so air can pass out of the tank while you fill it but overfills won't end up in the bottom of your trunk.
Hey gang, can someone help me out with a little "where's it at" mystery I am having. Of course the latest '95 AWD TSi we just picked up is missing squirters in the c/f hood, but everything else down line is gone too. I am trying to figure where the line comes from that feeds the under-hood line. I know the pump is out back, and presume the line runs either inside the car or under the rails, probably along the driver side, but where does it come out under the hood. Is it ported through the fire wall or hidden behind a spot like the brake booster. Any thoughts would be appreciated, and of course, a picture is worth a 1000 words. When it gets to 30 degrees this weekend I want to play under the hood...
Thanks, --Mike
The line starts in the back at the pump, travels behind the trunk plastic panels, then the rear seat plastic panels,
remove the running board on the passenger side (pull straight up, it's held on by metal clips on the bottom),
and you will see a black plastic piece, the line runs underneath it towards the front of the car,
where it passes through the firewall on the passenger side at the top,
and comes into the engine bay here,
where it is then split into two hoses by a tee and ran to the squirters.
Perfect, on the firewall under the vehicle info sticker. That is the perfect picture of the battery set up I need too....
Thank you! --Mike
can find my fluid tube that run from the rear washer motor in my 95 eclipse can someone tell me where to locate the fluid tube or can show me a diagram to show me how the line is run thru the car from the trunk up to the engine area.thank you
It runs on the left side.
Remove the gray scuff plate (driver side), there you find fluid line behinde the cables and the trunk release.
