Boost gauge noise?
Spaniel1287
195
Jan 30, 2005
Daven, Iowa
Ever since I installed my boost gauge, whenever the dial is in the Vac section of the gauge, u can hear a ticking noise. I could best describe it as a spark. Its not too loud but if u lean forward you can heard it. When its under 0 and in the Vac area, it sounds like it is sorta sparking. Any ideas on this wierd one?
Are you sure the noise is coming from the gauge itself? If so it would have to be something with the lighting. Twist the black part and pull out the light and drive like you do when you hear the noise to see if that is it.
Attack Eagle said:
putting a smaller diameter vacuum connector inline is a known fix for buzzing guages under vacuum.
True. Alot of the time you can hear the resonance of vacuum through the boost gauge line. Its even worse on the oil pressure gauge if you run a mechanical with a copper line. :notgood:
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
