boost gauge hook up question
dkrugg24
84
Dec 30, 2010
Sterling, Illinois
so i hear the best place to hook up a boost gauge is in the FPR line... well where in the line (or which line) do you put the T in to tap it? And the electrical where did you tap into mine has to come on when the car turns on because its a tinted gauge and lights up upon ignition?
yep manifold line. if you use the other one, the gauge will intermittently not work.
Use the line that goes between the fpr and the intake manifold. I tapped mine about 2 inches away from the solenoid and has been working great for 4 years.
ok does the gauge light turn on when the car is on because my gauge face is tinted and cant see it at all when the car is off so when the key turn on the gauge light has to come on also not when the headlights turn on? so i need to hook to the ignition switch but dont know which one is the power wire?
If you wire it to the dimmer switch it will only come on when the lights come on. You can wire it to your cigarette lighter wire or just find a fuse that has ignition power and run your power wire from there.
What kind of gauge is this? Mechanical or electronic? Is the gauge supposed to change colors when the headlights are turned on?
no it mechanical its a JDM gauge its tinted black when off cant see anything and supposed to illuminate when the key is turned on the instructions that came with the gauge say to hook into the ignition switch but i dont know which wire because it dont say on the instructions it jus says power wire to ignition switch and neg to the battery and no it dont change when the headlights turn on its either lit or its not (car on, car off)
Easiest way to do it then would be, instead of cutting into any wiring, to find an empty spot in the fuse box under the dash and tap in there for power. Put a spade on the end up the hot wire and put it right in the slot for a fuse. Wire the ground to a bolt under the dash. You can check for a good spot in the fuse box by using a multimeter. Put your positive probe in the empty fuse slot you want to check and put the negative on your ground spot, if you get ~12V when the key is on and 0V when its off, you've found a winner.
thanks for the idea i will try it and hope it works and ill let i you guys know!!
ok guys i got it! i just tapped into the ciggarete lighter and it works just fine! thanks for all the helpful ideas and all the help!
I tapped into the cigarette lighter.
This is a common practice. I am even guilty of doing this in the past, I feel ill when thinking about having done it that way. I have since found better methods which I outlined above.
  • For sale 2g Remanned Mitsubishi 2G AWD Auto Starter
    Remanned Mitsubishi 2G AWD Auto Starter $60 + shipping & PayPal feesYou must be registered to...
  • For sale 4G63 NEW JDC Titanium Dipstick Handle
    NEW JDC Titanium Dipstick Handle $55 + shipping & paypal fees* these are $110 online ( save 50...
  • For sale 2g NEW OEM Idler Pulley & 2G Tensioner Pulley
    NEW OEM Idler & 2G Tensioner Pulley $70 + shipping & paypal fees* idler pulleys are about $89...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
