Boost Creep??
Jeff822
636
Jan 22, 2006
Easton, Pennsylvania
My boost gauge will go to 20psi at WOT and then my car will hesitate then go as if nothing happened. What can i do to fix the boost creep if that is what it even is. I dont have a boost controller yet so i dont know how to get it back down to stock and what can i do to keep this from coming back in the future. Can this hurt my car or cause problems for the engine?, all i have is 3 inch downpipe, 3 inch exhaust, short ram and blow off valve, stock turbo and fuel system, thanks
yea im pretty sure its a fuel cut, it just hesitates a second then goes, is this from boost creep? how do i stop it? i dont have a boost controller
20 psi on the stock snail? Are you sure your boost gauge is working right. I dont think that the t25 can even hit that high. You can run a line from the wastegate to the nipple on the turbo and that will put you in the 12 psi range or so and will cut down on boost a little. I would check the wastegate as that is probably the cause of this.
-Anton-
