boost creep problem...
Iryoku
93
May 31, 2005
Brooklyn, New York
If I install a external tial wastegate 38mm on my exhaust manifold, I wont get boost creep from what I understand.
Now my question is... that these external wastegates come with a spring for certain psi... lets say I get the one for 14psi and in the future i want to go more, its possible to change the spring? or can i just leave it as is and run more boost/psi?
_________________
Iryoku. Now my question is... that these external wastegates come with a spring for certain psi... lets say I get the one for 14psi and in the future i want to go more said:
I remember asking this question about five or six months ago. It is a good idea to get a 14 psi spring and just running more boost using your mbc or ebc, when you want to up the boost in the future. Hope that helps out :thumb:
ahh ok so lets say i ge t a 14psi spring, and stock boost is 10, now the boost is going to jump to 14?
a 95 gst can handle 14psi almost stock right?
also in the future i want to put a t28, my main goal is 300whp... the 14psi wastegate can handle psi in the 20's?
Yes just with some supporting mods. Example bov(1g,greddy,hks just something better than the 2g bov), exhaust, rewire your fuel pump, air filter, boost gauge.
I'm assuming your talking about the Tial 38mm wastegate, so your answer is yes without any problems.
A 95gst should be able to handle up to about 15psi. However, at a minimum, the stock BOV should be replaced with a 1g BOV or aftermarket BOV because the stock BOV will leak at these boost levels making your tubo work harder than it needs to.
The 14psi wastegate should be fine at higher boost levels. However, to run at these higher boost levels (20psi+) you'll need several mods including an upgraded fuel pump for starters. Also make sure you are not running at a boost level which is beyond the efficiency range for the turbo.
Iryoku said:
yeah thats the one im talking about, what do i need to install this
The Tial externl WG comes with everything you need to install it. The only thing you would need is to weld it to either your exhaust manifold or O2 housing. The best place is off the first runner of the exhaust manifold.
Iryoku said:
Do I need a weld flange? if so which one? And what exactly is it?
You need to weld the flange onto your exhaust manifold just take it someone who you can trust to weld a flange onto the 1st runner of your exhaust manifold.
Or you can buy SBR exhaust manifold and the WG will bolt right on. Heres the link to check it out http://www.slowboyracing.com/more.php?id=1891&
