Boost controller out of adjustment
Scoobystyl
277
Nov 5, 2011
Denver, Colorado
What are my options im running a precision 46mm gate with the heaviest springs installed and my boost controller turned all the way in. How do i raise the boost more, im at 33lbs now and would like 40 +-
Anyone ever replace the spring in a hallman pro boost controller with a heavier one?
If your running the bottom side of the wastegate try moving to the top side to pressurize it. but be careful, you'll have to turn the hallman all the way in and back it out until you get the desired boost level.
I have the strongest springs installed a large medium and small. 3 total, and am running both ports on the wastegate. Btw precision supplies extra springs unlike tial so i have 6 or 7 total.
What does it net you just running wastegate pressure with no halman? There's 2 different springs depending on your model hallman, one allows 5psi adjustent (roughly) and the other, stiffer spring allows like 15? I think.
That is only for the pro rx model with the ceramic ball, i believe the pro has whats equal to the heavy spring for the rx. wastegate pressure is 25.5 psi thats with the large 18psi spring + medium 6 psi spring + small 1.5 psi spring
Well i took the boost controller apart and figured if i take a pen apart a can put the spring inside of the stock one, i havent tested it on the car yet but it seems to adjust easily and works like it should when blowing in it.
