Bolt/Screw Sizes
MJ'sbtch82
Feb 10, 2013
La Center, Washington
Does anyone know the sizes/thread for the following parts:
The bolts that mount the engine bay fuse box?
All the interior screws?
Bolts that mount the ECU?
Bolts that bolt down the two backseat pieces?
Front drivers side and passenger side seats?
M6 x 1.00mm pitch x 16mm long
Specify as there are way too many to sift through to give you all of them.
The upright cushions to the floor? M8 x 1.25mm pitch x 22mm long.
Brackets to the floor? They use two M10 x 1.25mm pitch nuts for the front studs. The rear bolts are M10 x 1.25mm pitch x 30mm long.
On what part of your 2G? Or do you mean the whole engine? Most will be covered by M6 x 1.00, M8 x 1.25, M10 x 1.25, M11 x 1.25, and M12 x 1.25.
