Bolt sizes..
Colt90tsi
202
Dec 28, 2007
Lake Stevens, Washington
Anyone know the sizes of the following bolts:
Front/rear engine mounts
Fuel rail to intake mani
Thanks
Shawn, did you pull that info from the 2g FWD bolt guide?
The fuel rail bolts sound correct - CAPS shows 8x6 (8mm by 6x length). The program doesn't show thread pitch.
Which motor mount bolts are you looking for? The ones that go through the mount itself or some of the other ones?
Actually i did thanks for asking b/c i thought it was for the 1g awd. Just have it saved under bolt sizes. I know i have one here some were just cant locate it. But im 99% sure the fuel rail bolts are the same. Not quite sure on the motor mounts.
the mount bolts are size 14. the fuel rail are size 12. do you need the bolts? I have extra if you want them
Nuts and bolts are sized by the diameter of the shaft, length, and thread pitch like Shawn said.
While we may refer to the size of the head when we are working on the car that's not how you buy them.
Thanks for the reply everyone, I am looking for the bolts that go through the rear/front mounts.... Are the 2g bolts in the wizard the same?
