bluemax fic 1250 questions
redpit
42
Aug 10, 2009
brooklyn, Maryland
i would like too see those who run pumpgas only on these injectors, What are gobal and deadtime settings. i have seen plenty of e85 post on this topic , But hardly any for pumpgas How do they ilde? what tuning system do you using to tune it ? i 'am using ecmlink v3.
Its very simple math to figure out your global... see this
An also deadtime an global will vary from car to car depending lots of factors
Hope your not expecting to punch in someone elses numbers an be good to go...
Did your injectors come with a injector latency sheet? Or did you get them used?
As far as IDLE on gas as long as you get your tune dialed in you shouldn't have any issues as I run Bn 1450'S an had zero issues with idle on gas when I made a quick gas map to switch to before going back to E85 when I first bought them...
I have searched on here for those running pumpgas on these injectors.What gobal and deadtime settings are you running on pumpgas? How do they idle and cruise ? what are you using to tune them with , i have seen plenty of e85 post. What i haven't seen was some pumpgas post for bluemax 1250 cc injectors?
I 'am getting some opinions on this product from people that run them with pumpgas . some real world knowledge. just because your car runs fine with those injectors dose not mean the next one will.
That was for the guy with the 1450 cc, i did not mean to duplicate the post my system crashed for i second i did not think it posted ,calan sorry for the duplicate
Since you seem to have a better understanding of this all then I do...
Please explain ,
Why not?
Maybe you will in the process of that will start to understand fully what I was telling you...:thumb:
Well i brought a set of fic 1600 cc injectors from a guy that had them on his car with no easy box . on his car they ilde perfect. cruise nice with no hiccups.On my car we couldn't get them to even idle right.I drove up to ecmlink and talk to them about the problem i was having and they told me 1600cc are a hit or miss. some work fine and others don't. And this was on the v3 model.i heard the same thing about the 1450cc bluemax i was about to purchuse.Before i buy a third set of injectors i want to see everyones opinions on the bluemax 1250cc injectors are they to hit or miss.Can they run safely on pumpgas with properly being set up on just ecmlink. so i'am trying to gather as much pumpgas informaition as possible on 1250cc bluemax injectors as possible.
whats the power rating on these? will they be a good choice for built moter on race fuel with pte6266 on 35lbs? dsm v3 tuned
