block bore questions
Silent_White
168
27
Feb 12, 2010
spokane, Washington
I purchased stock pistons, 20 over and had my machinist bore out the block... I haven't put it back together but am thinking about using forged pistons instead. Can I buy 20 over forged pistons and be ok, or should the new pistons be 30 over and have the block bored again to match the new pisotons?
yeah.. thats what i did the first time. I'm not quite sure that you actually read my first post.
If you want to use forged pistons than you are going to need to have the cylinders honed to get a little extra clearance for the pistons.
The block may need to be honed an additional .001 for the PTW to be correct
So you should be close, just need a touch up hone with the proper grit stones for ring seal.
    • george bromwell
    • pma1123
    • Sdcryan1
