GVR-4 Black Top CAS vs Green Top?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
Lots of threads on this but not quite what I was looking for. Most threads refer to can you throw it on a 90 or 2g etc., what pins need to be swapped to make that happen and things like that.
I am troubleshooting an issue on my 91 GVR-4 (6 bolt) and have a Black CAS at my disposal. Might have to swap it out during the troubleshooting process.
Guessing it is a direct swap with no need to mess with pins? Is it that much better than a green top?
Conversely, can I put that green top cas on my 1g 7 bolt Laser if the problem turns out not to be the CAS?
Thanks.
Its simply more accurate and less likely to drop the dreaded p300 code on 2g cars running a 6 bolt, either will work and they swap freely between each other, of course you have to reset your timing if you move the one thats in there or swap it.
