Biggest noob question: STARTER
goldeninja20
589
3
Dec 5, 2010
Norton, Massachusetts
Just finished my build up and dropped it in. The starter had not been wired when i took it out. I searched and i couldnt find which wire belongs where. The picture shows how i have it hooked up now, is this correct? Also i know this is kind of combining two threads but, where do you guys mount your fpr on the firewall, there is no spot for me to mount it without drilling and tapping new holes.
Power,ground, and the little clip.It's simple.
There is no place to mount the afpr on the firewall,because the car did not come with an afpr.
Drill and tap.Or get a bracket that mounts to something.
and you should be able to mount your fpr where your old fpr solenoid rack was mounted without having tomdrill new holes.
If you try to start the car like this it will catch the wires on fire and burn your hand. Trust me i did it two days ago. I should have become a member on here before i tryed to wire it up haha
Yes, the highlighted wire is a ground. It should lead from your battery ground to the tranny some place (starter bolt). And the starter power wire to where you have the highlighted wire. The terminal the power is hoooked onto is a blank.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
