Best Turbo is...........
4g63telantra
454
Dec 10, 2004
Toronto,
Im in the look out for a new turbo for my car.
Some mods I have is a built 2.0 6bolt, with 9:1 wiseco pistons and eagle rods. Also its a FWD car. With a T3 Manifold but I dont mind going with a T4 manifold. (6-an fuel lines) DSMLINK etc...
I was looking into a Garrett Turbo......
GT30
GT32
GT35
GT37
or a
GT40
Any Pros/Cons of any of these Turbos? for my set up?
I would say dont go with the GT40 because it will take a while to spool on a 2.0, I would say a 35 or 37, I would go full gerrett for which ever one you go. Either of those 2 turbo's will be decent spool on a 2.0, but it will have enough lag, that you will have better luck with traction. You can get either of these in a t3 flange.
Dustin
Only you can answer that question. You pretty much named all of the popular GT turbo's. You need to decide what kind of powerband you're looking for. You do realize that there is a huge difference between a GT30 and GT40?
If its a drag car, go with a GT37 or a GT40
A street/ warrior GT32 or GT35
like they said, you first need to decide what type of purpose your car will serve, then make a decision on what size turbo you will run with. regardless with any of these turbos, you must make sure your valvetrain is up to the task b/c smaller discplacement=more rpm's needed to run the turbo.
