Best place for power wire through firewall? Passenger side 1G
Maxthepersonz
Supporting VIP
350
63
Feb 3, 2014
Madison, Wisconsin
I am relocating my battery, I can't find anything to solid to answer this question. Really don't want to drill into the firewall unless I have to. Any way to make more room under the dash without removing it? Can I take out the air box or something while leaving the dash in? Just seems like I have no room and I wan't to do this the right way.
wrap it in some loom also to make sure you have it protected .
Yes, and remember the grommet, it's the difference between a car, and "I used to have a Dsm before it caught on fire".
Could either of you post a pic from inside and outside the bay and interrior where you went through? I love this car and refuse to drill in the wrong place once LOL. I have gromets and loom no fires here :)
I punched a hole in mine last week for N2O and water/meth. I will be working on it again today so I will try to take a picture. Mine was close to the wire loom but worked out perfect. It came out right beside a bracket spot welded to the firewall where the battery box is located.
I tried to cut into the grommet a bit that holds the harness in and tuck the wire through with no luck at all. Couldn't find the wire in my interior and now I'm dissapointed I cut into the grommet. Any advice for running it this way? Either way still really want firewall and interior pics cause I will probably end up drilling. Want this car going ASAP. That would be sweet 1990TSI.
Sent mine thru with the ecu bundle, worked out great.
Here are a few pictures of where I went through at:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
