belts..
turbo98eclipse
1,096
15
Jul 27, 2004
northern, New Jersey
what are the two belts next to (to the right) the timing belt? and would replacing those be as difficult as replacing the timing belt? thanx guys :dsm:
This is how it is on my 91, pretty sure its the same (or similar)
The belts are the water pump belt/alternator (could include A/C if applicable) belt and power steering pump belt. Very easy to replace.
For the p/s belt, loosen two bolts, one is on the exhaust manifold side (the pivot bolt), the other you have to position the pulley so you can get a socket though one of the two holes. Then loosen off the tension. To keep the belt tight, I just used a large wrench, braced it between the p/s pump and the head, and pull til tight, then tighten. Follow reverse for install.
The alternator belt is very similar process. You need to loosen off the pivot bolt (hard to get at, near the bottom of the alternator), then there is two bolts used for tension, both perpendicular to eachother, loosing the one that goes through the alternator mounting bracket first, then loosen the longer bolt that is used for tension. Again, reverse is for install.
Its a huge deal if it happens at the wrong time. If the p/s pump went, you'll just have manual steering. Water Pump/ alternator would be a bigger problem as water will not circulate and cool the engine, thus overheating. Also the alternator will not be running, thus running your battery dead....it'll stilll run though, just not a good idea. If your worried about them breaking, they probably need replacing, they're only about 25 bucks to replace.
yea cuz i was looking at them the other day and the one closest to the timing belt (power steering belt?) is like dry rotted and the tracks are starting to break off...the timing belt and the other belts look good though. the one which im concerned about is the one closest to the timing belt enclosure and is up higher than the rest of the belts around it...p/s belt? i can take a pic if you're still not too sure which one im talking about
Sounds like the p/s belt to me.....if its a V-Belt, it's definatly your p/s belt. If its got ridges on the inside (ribs) it's the alternator/water belt. If it looks like the way you describe....replace it.
While you're in there, make sure to replace the harmonic balancer as well, it'll save you a load of trouble (it's the bottom-most pulley in the loop.) 80 dollar part or so from mitsu, and you already have the belts off, might as well change it, because when it goes....so will all those precious new belts (it's what happened to me when I first got the car and decided to replace all the acc. belts.)
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
