Belts
trixtert
48
Sep 26, 2004
Calgary,
Dumb and noobish question to ask but do the Water pump, AC, Power Steering Pump and Alternator have anything to do with the timing. I pulled off all the accesory belt but the main crank pulley and Timing belt are still on. My question is can I rotate to TDC with the the accesory belts off?
Yes, you can. When rotating to TDC, the only belt you need to worry about is the timing belt.
Thanks alot
When I pull the Timing Belt off how do I keep the timing when trying to take of the Balance Shaft belt?
use the timing marks then. cams should line up with both dowels on the top side (compression stroke) and then the backplate on the crank sprocket has a mark on it, and then the oil pump sprocket has a mark on it, as does the balance shaft sprocket.
sorry, i just noticed you have a naturally aspirated model, the whole idea is the same, keep things lined up.
Actually I pulled out the 7 bolt N/T engine and I'm in the process of doing maintenance on my JDM Cyclone 6 Bolt engine before dropping it in (Timing Belt, Balance Belt, Thermostat...)
Using the old engine as a reference I took a closer look around the Balance Shaft pulley and I didn't see and Timing Marks there.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
