2G Bellhousing Bolts
2g420aeclipse
57
Jan 3, 2016
houston, Texas
I'm putting the transmission back but I forgot where the bolts goes on to the bellhousing to the engine block. The bolts are in different sizes so I don't want to put it in the wrong Place. This is the bolts that came out from the bellhousing and the engine block. I just need to know where the bolts go on to the bellhousing and the engine block
In your Pic of 5 bolts: Left 2 go in the bottom 2 red circles from the Block side, Middle 2 go in the top 2 holes from the transmission side. Not sure on the right bolt I dont remember that one.
Source is I did my 420a's transmission like 2 months ago
Lol that would work. Oddly he should have 2 left bolts and 2 middle bolts not the 1 and 3 he has. It doesn't really matter on those really(except the pointed one, that won't work on top) because they are the same thread and size.
@dk7868 specifically, you posted this question in a thread that's asking about bellhousing bolts for a 420A (n/t) 2g. Since you've got a 4G63 this is what yours will look like, if you have a 6-bolt bottom end then the bolt @ 9 o'clock isn't used.
Very good reference Corey!
Going forward, one trick that may help keep things more organized when using multiple bolts to attach something is to number each bolt in a clock-wise fashion. Take a sharpie of grease/paint pen to number each head as you remove them. Then all you have to remember is where to start (as close to the 12-1 o'clock position as possible).
