broken bellhousing help
boostedstang
May 23, 2010
dothan, Alabama
whats up i got a question. i recently broke my bellhousing. problem solved i welded it up. have not had any problems with it. well the other day i got a bad vibration and found out my bolts came loose. well the sleeve that the throw out bearing rides on is now broke.:ohdamn: has anyone had this problem before. how hard is it to take the bellhousing off to weld this back on or can you just get another bellhousing. if anyone has one they would like to sale hit me up. i am in need:confused:
I found this:
89-94 BELL HOUSING, $150 used, in good shape.
Here:
Garage Sale - Team Rip Engineering
Unfortunately the bell housing is hard to find in good shape because of cracking and worn TOB sleeves.
If you get a replacement you'll probably need to reshim your bearings for proper preload, and you should use blue locktite and a torque wrench to bolt the transmission to the engine.
ok guys got it all back together and running good. i ended up putting a sheppard built tranny in it a buddy had:hellyeah:. i also have a extra transfer case if any needs one. perfect condition just let me know i really need to sale it.thanks
