Bellhousing troubles.
1gAWT
71
May 14, 2011
Lincoln, Nebraska
Could someone provide me with the specs of the rear bell housing bolt (the long one) and a starter bolt spec. It sucks loosing bolts :(
BAG AND TAG FTW
All of the bell housing bolts are the same diameter and thread, even the starter bolts. Take a long one that you already have and thread it in LIGHTLY until it bottoms out, and use this measurement as a reference. Bring the bolt you have to a hardware store and match the diameter and thread, and use the measurment as a reference of length.
I usually go a thread or two shorter just to play it safe. The bolts should never bottom out all the way inside.
Hope this helps.
