Resolved BCS help
aaronth777
92
27
Apr 12, 2015
Dayton, Ohio
Hello all, I've recently decided to move to North Carolina and take my GSX with me. But one problem, they do emissions testing. So I've been going through my CEL codes trying to resolve all of them, but I'm having a hard time with code P1104 (Turbocharger Waste Gate Solenoid Circuit Malfunction).
The previous owner removed the BCS, so I bought one to plug in. But I can't find the right connector to plug it in to. I found the post on this site with all the 2G engine bay electrical connections, and it says the BCS connector looks like this: http://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/page-2#post-151542249
But when I went to find that in my car, I don't see it. The closest thing I can find is this connector in the attached pictures, but that has 4 connections instead of 2, and has 3 wires in the back instead of 2. Are these wires the right wires, but maybe a previous owner changed the connector at the end? or am I looking in the wrong area for the wires? (on the passenger side of the radiator, under the air filter?)
It should’ve been there by that one. The in your hand is the generator relay if I’m not mistaken.
You're absolutely right, thank you for the clarification. I'll be ordering that relay soon, thankfully it's only a backup relay so it can still drive without it. But anyone have any insight as to the location of the BCS wire?
A-100 is BPS connector
Maybe go back thru that leg of the harness and see if someone eliminated it?
PO could’ve eliminated like “wrencher” suggested or tucked it. If it’s there, it’s clearly tucked probably passensger side bumper area where stock side mount goes through frame wells. Trace the harness like mentioned above good idea
Thank you both, that diagram was a huge help, I was looking in the wrong section of the wiring harness. I found the wires and figured out that the PO cut off the connector altogether instead of just unplugging it for some reason. I crimped connectors on the end of the wires that fit into the BCS and got it all figured out, just gotta see if the code went away. Thanks!
