basic maintinace
flush/drain/refill radiator with distilled water & coolant...
might as well go ahead and tackle trans and differential oil, transfer case to..
Most people would tell you to go OEM with the Timing Belt. Do you trust Autozone with that important of a part?
I installed a fuel filter on my friends 1g GSX and decided to do mine as well. I was trying to see if I could get to the bottom nut under the filter but couldn't seem to get in a good position. I took out the battery and the top banjo bolt will be easy to remove I'm just curious about the bottom nut. So for all of you that have replaced your fuel filter on your 2G Turbo post how you got to that bottom nut.
blcknspo0ln said:
pepboys :thumbdown
was typing this but realized you guys arlready posted.. OEM is the way to go!
oh btw, 60k service on 2g's also entail swapping out the t25.. as it is recommended per DSM bible :)
But following that bible his 60k miles maintainance service will run him alot more money than it would normally. ;)
(turbo, exhaust, ic pipes, bov, inectors, pump... and so fourth)
:laugh:
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
