DSMPT
DSM Wiseman
- 3,489
- 3,351
- Jun 12, 2014
Japan / Mexico,
Arizona
A simple answer for you why you don't see it in the right position is, because you are doing it incorrectly, including the tensioner. I don't know maybe I didn't explain well myself above or you don't understand...@DSMPT ,when I do focus on just the horizontal timing marks, the dowels are not at 12, when the gears are adjusted to their factory zero. Also using the tooth circled in green does not allow the dowels to be at 12 without adjusting them.
If you are not sure what I am talking about, I would recommend to get the tool like the one in the Jeff's pic below. With that tool, you can't set the cam gears position incorrectly since you can't put the tool in if the cam gears positions are wrong.
