Banjo bolt sleeve?
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
What do you call this? Any idea where to get? I'm welding up some air lines for my dual gate setup.
I need one made from stainless.
Its a m10 for my tial waste gate.
Its called a banjo fitting.
They come in various sizes, metric and standard, and have various ends to make with whatever you are using, barb end, AN flare end female and male.
These can be found on most automotive parts sites, summit jegs, or our support vendors.
I dont think those fittings are meant to be welded to anything. Your best bet is to get a m10 x 1.0 to AN3 or 4 fitting for the wastegate.
Thanks. Trying to stay away from AN fittings. Gets expensive real quick. It will take 1 banjo setup vs 2 AN fittings for one line.
