Archer Fabrications
- 9,719
- 707
- May 9, 2011
Scottsdale,
Arizona
hey guys, i have been searching around and even asked PTE this question but they contradict what EVERYONE says about BB turbos (PTE is useless), anyway when i got the turbo, it came with an oil restricter on the oil inlet flange, its .030 like its supposed to be. but from my oil feed from the head, it doesnt fit on this -4AN MALE fitting, as the oil line is also a MALE. so i had to take out the restricter ON the turbo, and put the feed directly into the turbo, now, i do have an FP in-line filter with a built in .030 restricter (same size as the pte's). PTE recommended to not use a filter at all (because people don't check them enough) obviously i will be checking quite frequently, and changing my oil frequently. they also said to feed from the OFH for a BALL BEARING TURBO?!?!?WTF all i have heard is to run BB turbos from the head.
Turbo is an PTE SCM6152
my main question is:
if i have my oil filter/re stricter .030 at the head where the banjo fitting is, and have my oil line kind of loop around bottom the turbo before it goes to the turbos oil inlet. is this going to be adequate restriction for the turbo? or is it going to build up oil and slowly seep WAY to much oil into the turbo because the restriction is directly from the head, and has about a foot or so of line before it goes to the turbo. i would guess they had the restriction ON the turbo for a reason? or will i be fine?
