Balance Shafts
E'sTSiAWD
Sep 28, 2008
Denver, Colorado
i am going to remove my balance shafts from my engine but im only going to remove one of them im going to leave the oil pump one so my question is will any thing happen if i only leave one and cancel out the other one.
Please use the Search Function...
Possibly more vibration if you only leave that one in. The balance shaft system is a classic college level Dynamics or Controls Class "mass-damper system" developed and designed by Mitsubishi for this engine. (I can get more technical by no one probably cares.) By only removing one BS you are changing the inputs of the system and thus will get different outputs... ie more/different vibrations. A system that was once designed to eliminate vibration will now more than likely add more vibration since you changed the properties.
Chances are it won't kill your engine but it won't help...
for 25 bucks you can do it right...
Remember to block all oil passages...
Get the stubby shaft, rotate the bearing and plug the hole on the cover, easy cheap and 100% effective.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
