Balance Shaft Question.
scorpin
Mar 2, 2006
Hayward, California
Ok, my ? quick and simple, I now have 2 dsm's, a 94 Talon TSI AWD, and 96 Eclipe/
Talon runs perfect, the 96 threw the timing belt because the tension froze and the guy I bought it from didnt' want to fix it. Anyway, I was wondering the balance shaft can be be removed with the engine still in the car, and if so how would change the bearings to block the oil holes
Thanks again for the help
the balance shaft can be removed while the motor is in the car. you have to take off the oil pump and install a stubby shaft( avalible through SBR) as for turnig the bearings i can not tell you hoe to do that. but im sure it can be done i have seen others do it before:dsm:
Ive removed the balance shafts on a 1G Eclipse with the motor in and it was pretty difficult to me. The problem was getting the front shaft out. When you pull it out it hits the frame. So I had to unbolt the front subframe (I guess thats what you call it) to lower the engine just enough to slide it out. You can use the front shaft to knock both bearings out and to knock both in.
  • Wanted 6 bolt NT water pipe
    • chrisman287
