Bad vibration in rear under hard acceleration
spaugh
131
Jul 25, 2007
london, Kentucky
Ok i searched it seems alot of people have had this problem. Most of them were the carrier bearing. So i done the window weld fix and still same problem. I saw in one of the threads someone ask if the shifter knob moved at all. Well mine pushes back when I press the gas and pulls forward when I let off. When i was was under the car i saw the the front of the rear diff was wet with fluid were the shaft goes in. Is there a seal that needs replaced.
If you could help me i want to get it to the drag strip this weekend but i dont want to break.
Thanks for any help.
I checked the u-joints the way that you check a RWD. Try to turn it while in gear and see if there is any play and wasn't any. Is there a right way to put the window weld in there. I just crawled back under there and couild still move the drive shaft side to side but not up and down.
Once again thanks for any help.
