Bad Problems!!!!!!!!!!!!!
bigdrew123
Sep 24, 2002
my issue is that my 92.5 eagle talon will not idle right. it misses just idling. the other thing is that it stumbles on anything over 20% throtle. i've replaced the plugs,fuel pump,fr rewire,coil pack,transistor pack,swithced from 550's back to 450's,cam angle sensor,checked timing,iac valve,leak tested,and even replaced the ecu. it doesn't want to run for shit.oh, this car also has 2g mass with safc and big 16g. please help i need to this car running asap. :confused:
Sounds like a bad ISC motor/TPS, also replacing the fuel filter might help as well. When my car stumbled on acceleration the fuel filter was clogged.
