Bad idle on start up
99GS_Turbo
169
Dec 1, 2012
Boston, Massachusetts
So I have a 99 GST. When I start my car up in the morning, the idle will jump to about 3k until the car heats up and then it hovers around 600rpm. If I put the car in reverse it goes to around 200 and sometimes cuts off. It will also jump up and down throughout the day.
I took the car to Mitsubishi since there is one down the street and they said it was my Throttlebody so my question is can a bad TB cause this type of behavior?
I don't want to replace that if its not the issue.
Also they want 420 for an OEM TB. What would you suggest as a good upgrade from the OEM TB? If I have to replace it I might as well upgrade it now.
There are literally 100's if not 1000's of threads on this already.
The short answer to your question is yes a throttle-body shaft seal or leaking gasket could cause this but there are a ton of other things that can as well.
Before throwing money into the car there are some tests to can do to eliminate certain causes. The link below has a lot of info related to your situation.
Terry's Talon Troubleshooting Tips #3 - Fast Idle (aka. Idle Surge)
Thanks I was looking through other threads but with me always on the go, i had a hard time reading through them all...
