Bad Idle On Start Up
TreyDaBurna
57
Feb 14, 2013
Las Vegas, Nevada
Ok I just Bought my 96 eclipse gst it was running great for the first few days then one day i came out got in it(first thing in the am) started it up and it idled like it was going to die then it would bounce back up then drop again near dying..my remedy has been to rev it at about 2k til it warms up then it will idle normal by itself...anybody know whats going on?
check for vacuum line leaks or any leaks at all runnin to and from turbo piping,hoses,couplers.See if your Throttle positioning sensor(TPS)is set to factory specs or need a new one,Check your Idle speed control servo(ISC servo)you can do all that with your service manual from parts store and a $25 ohmmeter from wal-mart mine works great,Coil pack where ever your plug wires attach to besides plugs of course...Fuel pressure regulator might be bad.Do a compression test for each cylinder.If its an auto then check your neutral start switch.check plugs to see if they're fouled in ANY way.Best bet since I don't know what motor mods you have is to get a service manual and they have a trouble shooting guid.But start with getting the manual $15 give or take:) Oh,Check your IAC Valve(Idle air control valve)
This car is bone stock except for a new t25 turbo from who knows where...i kno i have some sort of leak because the car just isnt as fast as it was a week ago...and my stock boost gauge is damn near maxed out when im at 3k in 3rd gear and im moving at a snails pace.
but i have ordered a manual i should receive it today or monday at the latest
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
