Ayuda (Help) Lancer Evolution 2 GSR 94
Larsson94
Jan 4, 2024
Guatemala, Central America
tengo el problema que al poner primera velocidad y al querer sacarlo a rodar , el carro se apaga alguna idea ?
(I have the problem that when I put it in first gear and want to take it for a drive, the car turns off. Any ideas?)
You should take a video while the issue is happening and upload it, or explain more about the situation to narrow down the possibilities.
Deberias grabar un video mientras ocurriendo el problema y subirlo, o explicar mas sobre la situation para reducir las posibilidades.
It seems like you have many things to fix. The check engine and the CAT high temp waring light are ON. You should fix those first.
Se parece que tienes muchas cosas que arreglar. La luz de check engine y CAT high temp warning estan prendidos. Deberias arreglarlas primero.
