axles wont go in!!!!
cj8990
97
Mar 20, 2010
Chicago, Illinois
axles will not go into the differential!!! i tried taking the clip off and using pliers to compress it a little.. i tried pulling with all my strength and it wont go in! they are the right axles because they came out of this same differential... why wont they go in??
take a mallet or sledge hammer,with that clip on you cant put it in by hand sometimes you kinda got to hit it. try tappin in with a heavier hammer.
I just did the axles on my 97 GST, if you are sure you got the right part number they'll go in. Don't be afraid to back them out just slightly then ram em' in there the final inch or two with a little force. Not too much, but with the right umph they should click right it. Ensure your seals are seated properly and make sure to deliver the force as linearly as possible. If you try to force it in at an angle, even if ever so slight you will be there a while. When doing this, try grabbing the axle itself to get a more solid grip, not the outer end link on the hub end.
I had this same issue on my Pass AWD axle. Put the castle nut on the end of the threads and hit it with rubber mallet. Worked like a charm. Assuming the splines are the correct amount and not damaged.
Another tip is to to make sure ## c clip opening is on the bottom. The opening gives u less resistance. And with castle nut on and flush with the axel tap back in with a hammer. If more force is needed use a block of wood on the axel end and hit with a hammer. I use a 10 pound small sledge when dealing with suspensions.
Ops forgot put a small dab of vasoline on the c clip so as to keep it from spining heavy side down
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
