1G Axle/Tranny leak
dsmBear
387
10
Aug 27, 2012
Carmichael, California
I changed my transmission fluid, go on a drive everything's fine, except doing a pull a roatating clunk emerges so I drive home and park it. I come out next morning and all the fluid dripped out right be the teansfercase/passenger axle, seems like it was coming eight where the axle connects to transmission, so bad axle seal/axle ?
Well, go check then. How am I supposed to answer that if you haven't confirmed it visually.
check your halfshaft bracket bolts.
If you use bolts other than the stock bolts they usually break.
Okay I replaced the axle and the seal, it doesn't seem to have fixed the problem. I checked the half shafts bolts and they're fine. Possibly wheel bearing? But only started when hit pothole
I also didn't use oem bolts that hols the halfshaft in place but they're still there and not broken could this be cause? Is it possible to f*** up the half shaft?
Do you notice any excessive play in the halfshaft bearing? This could be the clunk you speak of. When I installed a new clutch I replaced the bearing in the halfshaft also......
did u ever fix your problem? I have huge issue w mine as well. 99gsx looks likt the half shaft is pushing down on the d/s axle seal making it leak gear oil....I don't know what to do
