awd transfer case spline?
dj-t
197
Nov 30, 2010
Sacramento, California
I have a 97 awd trans and found that the spline that goes to the transfer case moves in and out about a 1/8in (give or take). Is that normal or is there something that I should check for?
Once the transfer case is installed, that will not move at all, so it should be OK since the transfer case will hold the shaft in place. Question is, does the tranny leak from that shaft?
