22 spline trans and transfer case in my 92 awd?
95 tsi awd
131
Oct 14, 2005
belleville, New Jersey
i need a trans for my 92 awd and i can only find a 22 spline trans with the transfer case would i be able to swap that onto my 92?
:hellyeah:Yes, you can run a transmission with a 22 spline transfer case just make sure the shaft coming out of the trans matches the splines on the transfer case, I have the same setup 22 spline transfer and 22 spline output shaft to the transfer:thumb:
Yes, all driveshafts have the same spline. When i sawpped my 90 to 92 spec drivetrain all i did was sawpped the trans and t-case bolted right on..Driveshaft fit perfect.
Do u know the p/n's? You used. It seems my 90 Xcase doesn't want to mate with the center shaft spline
