NWHTanK
Freelancer
- 1,673
- 959
- Apr 23, 2011
Odessa,
Missouri
Yes the prothane kit does . Its a pain to find online but its a complete kit for the back of the car. I can post the part number when I get home. It is works with awd and fwd ....
Not sure what they mean by nylon nut. As long as it comes with everything shown in the picture you posted from STM, that's all you need.
It in my build thread. Page 5 . Part number for the prothane kit 13-301
OK found it, hey by the way, I've been checking your build thread for a while. BigFAN!!
Although there are lots of pics, i did not see any of the arm I'm changing out, maybe because you used 3g parts ?
Regardless were did you buy this kit from, and how much is it. it im guessing it works with 2G and 3G ?
Here is the link to his build thread.
http://www.dsmtuners.com/forums/dsm...gst-spyder-project-venom-5.html#post153350691
If this is the post you are talking about, I'm pretty sure the OP is asking about the rear tow arm, not the rear lower control arm. If I am wrong and the OP is asking about the lower control arm, then disregard everything I posted.
Rear toe arm:
Rear lower control arm:
Rear toe arm:
The above toe arm looks to be a fwd part. The diffrence between fwd and awd is the rod that passes thru the bushing. Its longer in the awd arm. The prothane kit compensates for this buy using a spacer for awd. Fwd just don't use the spacer.
Correct, that's what we were trying to confirm earlier in the thread. I've seen a few people use spacers, but I would rather get the OEM AWD part and not have to worry about it.
Nice build, btw.
ok, so let me get this straight, "IF" the toe arm is for an AWD then i dont need a bushing ?
Also according to Amazon this kit fit's the AWD 2G
Amazon.com: Prothane 13-301 Red Rear Upper and Lower Control Arm Bushing Kit: Automotive
And i found a thread on a 3G site, that relates to this discussion.
rear knuckle bushing - Page 3 - Club3G Forum : Mitsubishi Eclipse 3G Forums
You could call JNZtuning to confirm, but the arm should come with the correct bushing if it's the AWD version. If so, you'll only need the arm and the new eccentric bolt kit, which you already have.
i think im getting it now!
I removed the arm, but that SOB bolt is still ruining my life, any ideas on how to murder it ??
Should have cut it as close to the sub frame as possible then the bolt head would have just fallen out.
so anyone actually have advice ?Have you tried soaking it in penetrating oil?
