Dusty Landrum
Supporting VIP
- 1,005
- 1,674
- Jul 15, 2019
Denver,
Colorado
So I hate to post another wideband question but after doing as much research as I can I have to now. I googled and did thread searches and can’t seem to find my specific question/solution. So... here goes. Sorry for anyone that rolls their eyes at this if it seems really simple. Car is factory stock (except no cat exhaust).
I love the cobalt series of gauges from auto meter and finally purchased the pro+ wideband a/f gauge. After asking a few questions to a couple people and numerous searches I believe I have a decent understanding of the install but I am getting hung up on two things.
So currently I have the stock 99 GSX Manual Transmission ECU in the car. I am not going to hook any of the data logging things from the wideband up yet until I put my dsmlink ECU in. So this is to be ready for that, which is going to be done the middle of this week. There is NO cat on the car and I have the wideband sensor in the rear O2 spot. I know I have to cut factory O2 wire from sensor and splice in (solder and tape) the + signal output (blue wire coming from gauge) from the wideband to the rear O2 ECU wire pin 75. Then change sensor designation in dsmlink.
Question 1. Do I need to wire the (-) signal wire ( blue/black wire from gauge) to anything in the ECU for logging? I guess I am not sure if I need to wire this to pin 92 on the ECU. Anyone have any idea what this (-) signal wire is and what it is used for? Does it wire into the rear O2 sensor ground wire?
Question 2. Is it ok to have the 5v + signal output from the gauge sent to the ECU and not damage anything once the dsmlink ECU is installed?
Question 3. Does the WOT (brown wire from gauge) simply connect to ECU pin 84 to be able to use peak/recall and warning function? I think this is similar to what I have read on here about other wideband gauges but I want to be sure before I make any connections and risk inaccurate reads or possible damage to any components.
Side question: With the rear O2 getting it’s signal from the gauge, what should I do with the oem O2 sensor ground wire? I currently have the vfaq rear O2 simulator wired in so I don’t get a check engine light.
Out of all this is just typed, the biggest thing is I really just have absolutely no idea what I am supposed to do with this (-) signal output from the gauge and I can’t seem to find any info on it.
