Automatic tranny problem (WOT only)
GRNDSM
Moderator
2,421
196
May 16, 2002
Chelmsford, Massachusetts
Find myself a complete newbie when it comes to the automatic trannies :(.
My FWD Sypder GST has this problem from the day I got it: tranny is 100% fine under “normal” driving. But when going above 90% throttle, it seems to loose a 3rd gear (it goes to shift from 2nd to 3rd, but instead ends up in what feels like neutral). Sometimes it finds next gear right a away, other times it takes a while and I have to put into neutral and then into D to come back.
This happen about 30% of the times I go into WOT, so I try to avoid it altogether. The rest of the time the tranny is PERFECT! Well, as good as you can expect DSM tranny to be ;).
Any ideas?
How's your fluid/filter?
Do you have another TCU you can try to swap in?
