Auto with issues P0700 & P0750
wolvee123
82
Nov 23, 2003
granada, South Dakota
I've spent time searching with no luck. Please help.:aha:
A friend has a 98 eclipse automatic. It started having issue a few months ago, where it would go into tranny limp mode, 2nd gear, and flashed codes relating to failed shift solenoids A B and i think C and a PO700, module communication thing.
He replaced the shift solenoid pack, got a little better, same problem, then they found chunks in the tranny, so had it rebuilt. They checked the relays and just bought a used TCM and basically 2 of the same codes came back. PO700 and PO750.
2600 dollars later, same problems.
So what he is wondering, is there any correlation between the ECM and TCM. Maybe a sensor on the motor that could be sending wrong signals? something that may not be setting off the ECM, but cause the TCM to read wrong? Because this is the 3rd shop to do work on it and almost everything has made a noticeable difference but nothing has completely solved the problem. Any ideas at all?
(This is his typing, I tried to fix it as best I could. I also put it into first person.)
Thanks
http://www.dsmtuners.com/forums/420...-tranny-wont-shift-out-first-help-please.html I had the same problem turns out it was a intermittent tcu relay bout $6 at the local parts store the relay is up on the fire wall behind the battery by the brake booster in a cluster of three or four other relays. try that its only $6 more dollars to a already huge bill if that fails try doing a google search for Chrysler ETAX system that should give you some insight on the way the tcu communicates with the ecu. Hope this helps
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
