2G Auto transmission issues
Crossroads
Jul 2, 2014
Binghamton, New York
I have a 97 2g 420a gs auto. When I first start the car and put it in gear it slams in and is stuck in safe mode. When I am first taking off and want it to shift from second I flip the key on and off and it shifts. As long as I am giving it gas it stays in gear but when I let off and coast for a little bit it kicks out. I then have to pull over and restart the whole process. About a month ago I changed the fluid the filter and the shift pack. I changed all that because it was shifting a little hard here n there and kicked out of gear sometimes when cold. Just the other day I changed the transmission input and output speed sensors and didn't make a difference.
Hope u guys can help because this is my daily and I'm a broke college student, thank you.
The brain (TCU) that runs the tranny might have issues-why it heads to safe mode.
What fluid are you using - hope you're using ATF+4 fluids designed for Chrysler trannies.
Good luck - DSM
I'm using the fluid recommended on the dip stick. I hope it's the tcu because they're expensive LOL. Thanks I'll let ya know how it works out.
Good luck - DSM
I replaced the tcu and it didn't make a difference. Looks I'm just gonna have to do a manual swap LOL
Have to check into doing manual swaps with the 420A setup where many have done it with the 4G63 setup and been successful with it. Might just be more economical just to get your tranny rebuilt, or similar repairs.
Good luck - DSM
Sounds like the shift solenoid valve pack, you might have replaced it already but thats what it acts like.
I have already replaced it. But after I did someone had said I should've disconnected the battery. Would this make a difference?
