ARP SS exhaust studs not threading in completely
Talyn
443
19
Jun 10, 2012
Pittsburgh, Pennsylvania
Running into a bit of a snag with my ARP stainless steel exhaust studs, they aren't threading all the way up to the non threaded portion, I wouldn't even say they are coming close, they definitely thread in, but not all the way. Anyone else run into this? Is that normal? I've used their studs for the main caps, and cylinder head to block without having this issue. Is it possible I have the wrong set? ie. for a 6 bolt head? (I have a 7 bolt head) I'm fairly certain I don't since I think the 6 bolt set uses all studs, whereas the 7 bolt has two m10 bolts?
    • george bromwell
    • pma1123
    • Sdcryan1
