arp studs
I dont like the undercut studs as they dont hold torque meaning they stretch as the standard studs dont stretch as much torque up strong and last longer.
If this is for a 7 bolt I would go straight to the real good L19s MAP sells. They are worth it as the seven bolt studs are slimmer than the 6 bolt head studs and need all the help they can get.
If its for a 6 bolt head go with the standard.
I don't know man... WTF
Unless you plan on going Shep or Davis on us, I think standard will be just fine. Even then, they prob got some alien technology...
I agree, you'll be just fine with the standards...also be sure to use a good headgasket
yeah I think I will go standard for $100 if more people agree on here.
and yeah I'm going mls and will have the head and block perfect
Use the extra money to get a nice deck, if you haven't already done so. Get a quality HG that suites your application.
*Check out the thread about using copper/sealant on your mls, its really interesting. Science says no, experience says yes.
There are a few guys around here running the standard ARP's at or in excess of 400whp with no problems at all. Unless you are shooting for a balls to the wall throw money around build, you should be super happy with the standard ARP's.
