1G ARP Main Installation
jakk220
1,320
320
Nov 13, 2010
Akron, Ohio
Sorry for all of the threads lately, I'm just trying to cover all my bases. Anyway...
I cant remember from my last build, are you supposed to bottom out the main studs when installing them? I thought on my build we backed them out 1/4 turn before torquing them down... but I could be wrong.
Also is there a torque sequence for the 6 bolt main caps / girdle. I cant seem to find that anywhere either.... Thanks.
If you don’t at least have a dial bore gauge to check for roundness install the stock fasteners.
That is unless the machine shop installed them and did a line hone.
I just hand tighten them just barely tight and then install the nuts, torque them, loosen them and then torque them again, tighten them in a crisscross pattern in at least three steps to get to your final torque. Donnie is correct, you might be better off without them unless your main caps and block have been resized with them installed.
I too was in the same situation not that long ago. I just decided to go the safe route and have the machine shop install/line hone my studs and girdle. I have read that people have gotten away without shop work but I'm willing to pay for piece of mind.
He torqued them down to spec and checked them. He said an align hone was not needed. They were all within spec.
I just needed to know the torque pattern and stretch method. As well as if the studs should be bottomed out or backed out 1/4 turn.
Thanks for the information. Did you start with the center cap and work your way to the outer 2?
Yep, exactly. You really cant use a stretch gauge on them because they are in a blind hole obviously.
Thanks. If you have a sec chime in on my most recent thread. I'm trying to make sure I installed these main bearings correctly. I'm out in the garage now LOL
I have talked to three machine shops who told me its pointless, that installing studs in the mains wont throw anything off enough to worry about line honing on a iron block 4 cylinder. When I built my engine I used a dial bore gauge with arps and stock and didn't notice much of anything. I ended up using oem main bolts as I didn't wanna take the chance despite everything I was told. I really really would like to get to the bottom of this. Is there someone who can prove this based on evidence? I understand the science behind it. The thought is the stud distorts the mains. Now can the same be said for the cylinders? Most guys switch from a bolt to a head stud. When I build my motors I torque plate the block before honing with the correct fasteners. Not everyone torque plates let alone after installing new studs. The machinist basically said I could steal your money but im wasting my time. Those iron 4 cylinder blocks are rigid and the difference is negligible. I find myself repeating things because everyone else says it. We find plenty of guys who said f it and installed them without it and were fine. Has anyone heard of someone installing these and destroyed an engine because of it?
I have never personally needed to align hone any of the blocks that I have built. I have always had them checked, but none of them ever needed it. I'm sure there are some factors that go into play, such as how the engine was used and what type of failure it experienced. I could be wrong though
As far as the installation.... Make sure you chase all the threads and blow out the holes to get all the crap out. I then install the stud handtight and measure the depth with my calipers. Then I torque them in 2-3 cycles. I think most important is making sure the caps are seated properly. If I remember correctly I seated the cap with bolts first.....basically tapping the cap with a handle until all the bolts screwed in without much effort. Then I removed them and installed the stud.
My machine shop told me the same thing. So going off their word I assemble it and 40k miles of abuse never had an issue. I mean for some its a good piece of mine, but when my trusted machine shop says its not needed...I took their word since they build race motors on the daily.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
